0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 44 | My wood bed needs refinishing..the paint on the medal dividers is in great shape, but the seal on the wood has peeled. Is this simply a case where I remove all the bolts holding down the medal and remove the boards...refinish then re install....Or is it more complicated than that. I appreciate any insights and tricks for this project... Thanks in advance
Craig 1946 Chevy Mod Truck
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Basically thats it - unbolt and remove strips, then boards. Hopefully the wood isn't too far gone as far as cracking / checking. Search the Forum for finishing suggestions - everyone has a different approach / product they prefer. | | | | | Joined: Dec 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 44 | Bruce Thank you for your insights....I will be starting this project next week..should be fun Craig
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 46trucker: much has been written on this subject. Check out Mar-K site here at the bolt and you will find where they did a lot of test and recomendations. What ever you use just be sure to put about 4 coats on it, and be sure to get all sides including the edges and ends. Do a search in here are in the bed forum and you'll find plenty to read. A lot of hobbist ues the Helsman SPAR-urethane...just depends on what your looking for. | | | | | Joined: Dec 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 44 | Achipmunk Thanks for your comments...I have used the Helsman for wood chairs and have been very pleased with it...I appreciate the insights on where to look for advice
