| | | Forums66 Topics128,105 Posts1,056,551 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 24 Apprentice | | Apprentice Joined: Nov 2006 Posts: 24 | I am going to instal an Edelbrock Performer 600 CFM carb. and performer intakes. What would be a good cam to use? I would like a little more power, doesn't have to idle real smooth but with a little roll to it. thanks | | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | Use a Comp Cams 260H or a 268H High energy Cam. The 260 sounds like an engine running with a slight miss on one cylinder until it hits about 2,000 RPM, while the 268 has a more noticeable idle lick. Either one will work OK with a stock torque converter, or one with a 2,000 RPM stall speed at the most. Jerry
