2 members (RLB, 1 invisible), 182 guests, and 1 robot.
Topics128,079
Posts1,056,058
Members48,433
#511887 03/01/2009 6:46 PM
Apprentice
Apprentice
I am going to instal an Edelbrock Performer 600 CFM carb. and performer intakes. What would be a good cam to use? I would like a little more power, doesn't have to idle real smooth but with a little roll to it. thanks
Use a Comp Cams 260H or a 268H High energy Cam. The 260 sounds like an engine running with a slight miss on one cylinder until it hits about 2,000 RPM, while the 268 has a more noticeable idle lick. Either one will work OK with a stock torque converter, or one with a 2,000 RPM stall speed at the most.
