3 members (Uncles51, Woodcmiami, Mitch4445), 53 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#511740 03/01/2009 6:24 AM
I have a column shift 3 speed that has been cobbled up with a floor shifter and want to put in a floor shift 4 speed.My question is; what will I need to change over other than the gear box and floor pan?? I have a 61 chevy 1/2 ton with a 235 6 cyl and the donor is a 62 gmc 3/4 with a 305 v6
Riding in the Passing Lane
The drive shaft will be the biggest problem. Take a hard look at the 2 trans. & the length. Check with a local drive shaft shop. They can probably mate the one from the 4 speed to the back part of the 3 speed. Have you check out the 4 speed. Most of the GMC trucks used the NP trans. It can be identified by the aluminum top. The early ones back then were notorious for busted syncros.
1972 Chevy c10 Cheyenne Super
Ok thank you very mutch for yor help, This GMC was a camper special / never had a bed, would that make a difference in transmissions possibly a heavy duty? So your in Lenexa huh? I'm origonally from Topeka, small world.
