3 members (tesa, Bill Hanlon, Gray_Ghost), 76 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
#511593 02/28/2009 10:36 PM
My wood bed needs refinishing..the paint on the medal dividers is in great shape, but the seal on the wood has peeled. Is this simply a case where I remove all the bolts holding down the medal and remove the boards...refinish then re install....Or is it more complicated than that. I appreciate any insights and tricks for this project...
Thanks in advance
Craig
1946 Chevy Mod Truck
Basically thats it - unbolt and remove strips, then boards. Hopefully the wood isn't too far gone as far as cracking / checking. Search the Forum for finishing suggestions - everyone has a different approach / product they prefer.
1940 Chevy KC 1/2-Ton
Bruce
Thank you for your insights....I will be starting this project next week..should be fun
Craig
Craig
46trucker: much has been written on this subject. Check out
Mar-K site here at the bolt and you will find where they did a lot of test and recomendations.
What ever you use just be sure to put about 4 coats on it, and be sure to get all sides including the edges and ends. Do a search in here are in the bed forum and you'll find plenty to read.
A lot of hobbist ues the Helsman SPAR-urethane...just depends on what your looking for.
Achipmunk Thanks for your comments...I have used the Helsman for wood chairs and have been very pleased with it...I appreciate the insights on where to look for advice
Craig
