| | | Forums66 Topics128,128 Posts1,056,666 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 22 New Guy | | New Guy Joined: Aug 2004 Posts: 22 | will late model 16n. wheels from a chevy Colorado truck 07, or 08 fit a 50 chevy 3100.. I am thinking front disc brakes for the 50 thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. The bolt pattern is correct, but the wheel backspacing is way off. They will rub.
Bill Burmeister | | | | | Joined: Aug 2004 Posts: 22 New Guy | | New Guy Joined: Aug 2004 Posts: 22 | what wheel will work with a disc brake conversion on the front of a stock 50 chevy 3100 thanks. will spacers work with either application ? | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I think you are looking for 73 to 80 1/2 ton 4x4 wheels.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
