4 members (Otto Skorzeny, J Lucas, TexasA&M48Truck, Ed Atkisson), 86 guests, and 6 robots.
Topics128,021
Posts1,055,373
Members48,420
#508 08/14/2003 8:56 PM
ive got a 71 c-10 chevy...396/400 turbo/411 rear end....lmao...ouch!!!do you have any clue as to what rear end i can use to make this ol girl more driveable?i was told 308 but i dont think chevy used a 308 back then in a c-10.any ideas?
#509 08/14/2003 9:17 PM
Junior Member
Junior Member
Chevy offered a 3.08 in their '66 1/2 tons, and I just put a '76 Chevy K10 rear in a truck, which has a 3.07 ratio.
You might check with: http://www.ring-pinion.com/home.shtml for more advice. Also at this site, they have a calculator you can use to determine RPM at various speeds with various ratios and tire sizes.
#510 08/14/2003 9:25 PM
thats great...thanx for that info
#511 08/14/2003 9:26 PM
but...will that rear end fit up to my ol 71 frame?or will i have to make some mods?
#512 08/14/2003 9:45 PM
The rear gear ratios were availble for your year of truck too. A buddy of mine put front and rear `71 C-10 running gear into his `63 suburban and only had to modify the panhard bar as he was lowering it.
#513 08/14/2003 10:02 PM
sweet...but i also hear that a 71-72 long bed used a 3.18 gear.....wonder if that will work?
