| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2003 Posts: 7 Member | | Member Joined: Aug 2003 Posts: 7 | ive got a 71 c-10 chevy...396/400 turbo/411 rear end....lmao...ouch!!!do you have any clue as to what rear end i can use to make this ol girl more driveable?i was told 308 but i dont think chevy used a 308 back then in a c-10.any ideas? | | | | | Joined: Jan 2003 Posts: 43 Junior Member | | Junior Member Joined: Jan 2003 Posts: 43 | Chevy offered a 3.08 in their '66 1/2 tons, and I just put a '76 Chevy K10 rear in a truck, which has a 3.07 ratio. You might check with: http://www.ring-pinion.com/home.shtml for more advice. Also at this site, they have a calculator you can use to determine RPM at various speeds with various ratios and tire sizes. | | | | | Joined: Aug 2003 Posts: 7 Member | | Member Joined: Aug 2003 Posts: 7 | thats great...thanx for that info | | | | | Joined: Aug 2003 Posts: 7 Member | | Member Joined: Aug 2003 Posts: 7 | but...will that rear end fit up to my ol 71 frame?or will i have to make some mods? | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | The rear gear ratios were availble for your year of truck too. A buddy of mine put front and rear `71 C-10 running gear into his `63 suburban and only had to modify the panhard bar as he was lowering it.
| | | | | Joined: Aug 2003 Posts: 7 Member | | Member Joined: Aug 2003 Posts: 7 | sweet...but i also hear that a 71-72 long bed used a 3.18 gear.....wonder if that will work? | | |
