0 members (),
58
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | I took out the rear seating out of a Jayco van which turns into a bed...I took the seat apart and cut the frame (53"wide ) so I could locate the seat between the rear wheel humps..this seat is held down with four removal clamps that are bolted to the floor..
1946 chevy 1/2 ton panel 1937 ford coupe | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Provide some pictures and what is a Jayco van? What years etc? | | | | | Joined: Dec 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 112 | The travel van that I had was 1991 f---d E- 150 the inside was done by a company called Jayco...it was one of thoes vans that you could sleep in...This is where I got my rear seat for my 46 panel..It can be used as a seat or turned down into a bed..it was held to the floor by four clamps..which can be removed...I measured the inside of the panel and then I cut the frame to fit inside the rear wheel humps...53"..I have it now at the shop to be recovered to match my new front seats which I bought at summit..There are low back seats..I also used the mechanic's of the middle seats from old van they tilted forward and installed them in the panel. Now my new seat on the pass. side tilts forward..so riders can get into the back and also I can get a my battery box..Hope this explains what I did..
