3 members (1955 1 Series, Bill Hanlon, treegrower), 301 guests, and 3 robots.
Topics128,152
Posts1,057,012
Members48,460
I'm making a plate for the Mr. Gasket bellcrank to operate the 4 barrell carb I'm installing. I'm using the original pedal assy to push a rod. This bell-crank will pull a Lokar cable to work the carb by cable control. Has anybody done the on a 292?
Has anybody done this and can suggest or tell of faults to watch out for?
or
What they should have done . . . or what did work?
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
A 250, but similar, I changed to a cable when I installed the 700R4:
http://www.chuckthetruck.com/Page26.html
Original rod linkage:
http://www.chuckthetruck.com/page15.html
Jim,
What I did hasn't worked out very well. I used a Lokar cable and found it to be a waste of money if you run it anywhere near your exhaust (the heat of the exhaust binds the cable inside the sheathing). Not only that, but I've found that long throttle cables (as in the type setup we end up having when trying to mount 4 barrels on our straight six engines) tend to not give very good throttle response.
I started fabricating a throttle bracket about six months or so ago and never got around to finishing it. Many people here have surrendered their difficult, inefficient throttle cables for custom made throttle linkages and have not regretted. I hope to be the next one! wink
-ftyler
I didn't like the idea of a cable so I fabricated linkage based on the same principle as the 1 bbl linkage. I even used as much of the 1 bbl linkage as possible. It works the exact same, the only difference is the push-pull is horizontal instead of vertical.
carb linkage 1
carb linkage 2
The arm you see that's attached to the painted blue shaft is the same arm from the 1 bbl and working in the same capacity. Solid, mechanical linkage. No throttle response issues.
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
