1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#51048 10/11/2005 12:16 AM
Y
Junior Member
Junior Member
Y Offline
hello,
i have a 1971 c-10 and i have a bit of a problem. i 1st bought the truck with a 250 cid flat six w/ a manual tranny and i decided to drop in a v8. long story short, i dropped in an 83 305 and there is no where to stablize the z-bar. i have looked on the block to see if there was anywhere to mount it or possibly have a bracket set up, but i have not found a place yet. i am wondering if anybody could inform me of a kit for this problem or any solutions that do not require a lot of welding and metal work b/c i have no experience and no equipment to do the job. this is the only thing stopping me from getting my project on the road.
thank you
josh
#51049 10/11/2005 2:02 AM
Junior Member
Junior Member
Hey Josh,
I was told that not all small blocks are the same when it comes to the mounting bosses for the clutch linkage z-bar. Some small blocks have the boss(es) for the linkage and some don't. It should be about where you might expect. Inches above the oilpan and forward a few inches of the back of the block. It's been so long since I've seen them that I can't be too accurate in their location.
The blocks that have them can be used with either an automatic or a clutch. If they don't have them then you must modify or maybe use a hydraulic clutch.
Someone here will probably help you out.
Good Luck, Rick
I feel like I'm diagonally parked in a parallel universe.
