4 members (MarkT, WICruiser, Wally / Montana, MRMEROTH11), 113 guests, and 1 robot.
Topics128,068
Posts1,055,881
Members48,428
#509882 02/24/2009 7:05 PM
I'm in the process of re-doing a 235. While attempting to remove the lifters, I get them up about 3/8 of an inch, when I rotate the motor on the motor stand, with the rockers facing the floor, all the lifter drop evenly the same 3/8". Am I correct in assuming that the cam shaft must be removed and the lifters drop down towards the pan to be removed? Can the solid lifters be replaced w/hydraulic ones? If so,does the camshaft need to be changed?
tools94 #509884 02/24/2009 7:07 PM
If you want hydraulic lifters you must get a hydraulic cam to go with it.
58' 3200 235 3-speed/OD
ApacheFiend #509894 02/24/2009 7:20 PM
I thought that might be the case, any thoughts on the lifter removal?
tools94 #509899 02/24/2009 7:31 PM
Only the later 235 blocks (I think around '58 or so) were ALL drilled for hydraulics. Before that only the powerglide equipped blocks were. If you have an earlier block that came with solid lifters, hydraulics won't work.
waldo53 #509905 02/24/2009 7:40 PM
tools94,
The lifters come out through the top, they don't drop back into the pan. There is a ridge of crud/gunk that has accumulated where the lifter doesn't slide in the bore. You must grab the lifter with pliers or something and scrape the junk off as you pull the lifter up and out!
Stuart
atomarc #510047 02/25/2009 1:34 AM
Thank you !!!!
tools94 #510056 02/25/2009 1:57 AM
Apprentice
Apprentice
i spray carb cleaner around the lifters it softens the crud. then i clamp a hose clamp around the lifter and pry under it to pop them out. there is also a slide hammer tool made to remove them. i think it is k.d.
bob308 #510104 02/25/2009 3:30 AM
It's possible the lifter is worn/mushroomed enough on the bottom to make it difficult to remove. If so, both cam and lifters should be replaced. A good lifter will have a slight convex shape on the bottom where it rides the cam, taller in the middle than the edges. This, plus the lifter riding slightly off-center on the cam lobe causes it to spin as it lifts, equalizing the wear pattern. Flat-bottomed or cupped-out lifters are worn out. Check the bottoms with a straightedge like a machinist's 6-inch rule.
That's exactly what I found and new parts are on order, Thanks to all, They were a bit of a struggle to remove, but the trick with the hose clamp works great. thanks again!!!
tools94 #510741 02/26/2009 4:05 PM
That hose clamp is a good idea. It is possible to mark up the sides of the lifters with vice grips!
1951 1 Ton Completed
