0 members (),
159
Mod | | | Forums66 Topics128,260 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | 1949 AD, I'm about ready for the headliner and Windlace. Does any one have any advice as to the easiest sequence of installation for the headliner and windlace. Headliner first or Windlace? Thanks  Cleon
| | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | Don't know which you should tackle first. I can give advise on a tip for the windlace. I installed some on my 46 last weekend. A tip I learned on this site was to cut slits in the vinal where it bolts under the trim. That way you can loosen the trim enough and slide the windlace in. Use masking tape to hold it in place while you are working on other parts, tightening, moving, loosening etc. Also before the final cutting and tightening, close the door and test the fit.
Rick......... | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I would do the headliner first. Do a search on this site under headliner. There are a few diffenent ideas on the install. No matter how you decide to do it, be prepared for the most fustrating job you've ever done. I never want to go through it again and i've had my share. Good luck, Cecil........ | | |
