5 members (ShopRag, kurbside bolter, Ponchogl, cmayna, 1955 1 Series), 107 guests, and 4 robots.
Topics128,268
Posts1,058,375
Members48,485
#509005 02/22/2009 5:58 PM
1949 AD, I'm about ready for the headliner and Windlace. Does any one have any advice as to the easiest sequence of installation for the headliner and windlace. Headliner first or Windlace? Thanks headscratch
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
Don't know which you should tackle first. I can give advise on a tip for the windlace. I installed some on my 46 last weekend. A tip I learned on this site was to cut slits in the vinal where it bolts under the trim. That way you can loosen the trim enough and slide the windlace in. Use masking tape to hold it in place while you are working on other parts, tightening, moving, loosening etc. Also before the final cutting and tightening, close the door and test the fit.
Rick.........
I would do the headliner first. Do a search on this site under headliner. There are a few diffenent ideas on the install. No matter how you decide to do it, be prepared for the most fustrating job you've ever done. I never want to go through it again and i've had my share. Good luck, Cecil........
Moderated by  ndkid275, Phak1
