Brrrr
place holder
6 members (Charles in CA, Gdads51, klhansen, 2-Ton, joe apple, Forty9), 163 guests, and 1 robot.
Topics128,274
Posts1,058,428
Members48,489
Hi Guys,
Anyone have a tip for stopping interior door handles from slipping - splines are pretty smoothed out on handles, and on latch mechanism ?. I can't keep them tight enough with screws.
1940 Chevy KC 1/2-Ton
I've used a small strip of leather. Wrap it around the splines or any way you can. This helped on the spline issue. I'm looking for the inside door mechanism for my 46. They are pretty loose, worn out so I hope some one has a line on where to get some new or rebuilt ones.
Rick......
Has anyone thought of trying the liquid form of J B weld. I have on an occasion or two tried it and was supprised how much punishment that stuff can take. The liquid form is harder than the paste or stick form.
Hi west..........I had thought about liquid weld, but was concerned I would never be able to get handles back off if needed.
Your concern about once using the J B weld and not getting the handle back off is a good question & concern. I am thinking that even though the stuff is great I would think that one sould still be able to carefuly pry the handle off. I do know that once J B weld has been used heat has no affect on the softening or making it workable. Wores case senerio then the handle needs to be damaged in a way to remove. Replace it now or later if you at some point may need to remove. I good fix for now.
Brit,
If it was me, for a quick fix I would get some small Cold Roll pins and position the handle were I wanted it to stay and drill straight throug the handle and shaft all the way ...tap in a roll pin and call it done.
If later ya want to remove just use a pin punch and drive out the pin.
Just a thought.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Moderated by  ndkid275, Phak1
