| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | I'm re-doing a '57-235 that will eventually replace the one in my '52 daily driver.The filter sump had a 1/2 pound of sludge in it which had anchored the wrong filter FIRMLY inside! It's clean now! Napa ordered correct filter. Unit feeds oil thru top inlet, and after passing thru sidewall of filter and thru the 3/32 hole in vertical shaft, exits out bottom. Has anyone ventured to add additional holes to increase oil flow? I'm considering doing that, or shouldn't I go there? | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | You will likely notice an unacceptable drop in oil pressure. I vote don't go there.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Aug 2007 Posts: 55 New Guy | | New Guy Joined: Aug 2007 Posts: 55 | Being too old to do a lot of math, I can a least extend a concept. If the length of the connecting tubes were equal,as were the dias., we could calculate a flow. factor in the resistance of the filter,and the 3/32 orifice, and arrive at a modified flow rate.It still seems to me to be a pitiful rate of oil that is being filtered, unless pre-design called for a pathetic filtering rate. The supply point for this filter is at the top of cylndr head, whilst the remainder of the pump output supplies the rocker rail. I'm still not convinced that opening this orifice a little more would be harmful. What is the design output psi of the oil pump? | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | You know a lot more than I know, tools94... I got lost at the beginning of the explanation  I do think you'll get a lot more response to your idea though if you post it over in the the Engine & Driveline or General Truck forum where they get more traffic  | | |
