8 members (David Bush, kades51, BC59, MikeE, Bucker, MickeyP, Rexville48, dt235sd),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 14 New Guy | | New Guy Joined: Feb 2009 Posts: 14 | Does any one know what years of chevy or ford the high low gear shifter which gave trucks 3 low and 3 high gears and what it is called? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Professorpavy,
Would you be referring to a 'two speed' rear end. This was a feature of the differential, not the transmission. It allowed for two ratios, the installed ratio of the ring/pinion, and through a set up small gears, a lower ratio could be selected.
This allowed an under drive or a direct drive to be selected, independent of what gear the transmission was in.
Earlier versions used a vacuum actuator, and modern versions use an electric motor. They are still used today.
Maybe this isn't what you were thinking of.
Stuart
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Chevy called it a Double Reduction Differential and I know they had it in the post war trucks(WW2), maybe earlier.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | There was also an over/under auxiliary transmission made by Brown/Lipe ("Brownie") which was used in conjunction with the main transmission. It allowed a driver to have an underdrive/direct/overdrive selection for each main transmission ratio. A 4-speed became a 12-speed setup with the Brownie transmission in the mix. I learned to drive big rigs on a B-73 Mack with a Tri-plex transmission- - -two shifters and a 5X3 speed setup in the same transmission housing. Once I got it rolling, all the shifts were done without using the clutch. Jerry
