4 members (DoubleB, greenie-reddy, 41appletruck, Oswald), 85 guests, and 1 robot.
Topics128,091
Posts1,056,038
Members48,433
#509437 02/23/2009 6:45 PM
The last truck I purchased (1950 6400) had this vacuum pump booster on the firewall. It also had a small rheostat switch with VAC on the dial in the cab. I have found reference to this in my GMC parts book but not Chevrolet (GMC 23.3787 part #2233295) does anybody know how these worked or any more information on them. I assume it is a 6-volt powered vacuum pump that boosts engine vacuum like the optional fuel pump.
http://good-times.webshots.com/photo/2379570540102454676YQZtbb
http://good-times.webshots.com/photo/2145875240102454676VbBPfp
Apprentice
Apprentice
I have two of these vacuum assist pumps. One is a 12 volt model (used) and the other is a 6 volt model(new in box) They are made by Trico and I see them every once in a while on eBay. You put this in line with the vacuum going to your wipers or other vacuum accessories. When vacuum is low at high RPM's you flip the switch and the pump supplies additional vacuum to your accessories.
Why not put a vacumn switch on the manifold to switch it on automatically?
64 & 66 GMC long fleetside 4x4
Cartwright, OK
J M Offline
We used to use these on our 1950's tank trucks and wrecker. It was an aftermarket kit that was installed to provide vacuum for your wipers when you were working the truck hard like pulling a pass and you had very little vacuum from your engine. It was almost a necessity here.
Jim
Was this any better than the double action fuel pump?
1951 1 Ton Completed
J M Offline
It had it beat hands down. The double action pump just wasn't strong enough. Sometimes we would run both.
Jim
Apprentice
Apprentice
what is the part # on that 6 volt vacuum booster pump
GMC manual refers to it in section 23.3787 Part#2233295
