7 members (Hotrod Lincoln, mason86, klhansen, 32Fordpuchoptop, Ponchogl, Phak1, tclederman), 76 guests, and 1 robot.
Topics128,050
Posts1,055,672
#509423 02/23/2009 5:44 PM
Does any one know what years of chevy or ford the high low gear shifter which gave trucks 3 low and 3 high gears and what it is called?
Professorpavy,
Would you be referring to a 'two speed' rear end. This was a feature of the differential, not the transmission. It allowed for two ratios, the installed ratio of the ring/pinion, and through a set up small gears, a lower ratio could be selected.
This allowed an under drive or a direct drive to be selected, independent of what gear the transmission was in.
Earlier versions used a vacuum actuator, and modern versions use an electric motor. They are still used today.
Maybe this isn't what you were thinking of.
Stuart
Chevy called it a Double Reduction Differential and I know they had it in the post war trucks(WW2), maybe earlier.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
H Online: Content
There was also an over/under auxiliary transmission made by Brown/Lipe ("Brownie") which was used in conjunction with the main transmission. It allowed a driver to have an underdrive/direct/overdrive selection for each main transmission ratio. A 4-speed became a 12-speed setup with the Brownie transmission in the mix. I learned to drive big rigs on a B-73 Mack with a Tri-plex transmission- - -two shifters and a 5X3 speed setup in the same transmission housing. Once I got it rolling, all the shifts were done without using the clutch.
