| | | Forums66 Topics128,191 Posts1,057,364 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I plan on putting a water pump adapter on my '54 1-1/2 ton which will be powered by a '62 235 from a '62 c-10. What is the ideal water pump pulley to harmonic balancer pulley ratio so the water pump isn't spinning too fast or slow? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I'd say they are pretty close to one/one judging by whats on my engine. I'll try to measure them and post it here tomorrow. | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i used the plate on my 1960 235. i ordered the waterpump with a 3/8 pulley to run the alt. i reused the 5/8 balancer this lets the 3/8 belt ride low and reduce the pump speed. oh it may have been a 1/2 balancer im not sure but it works fine. philip | | |
