3 members (Peggy M, RLB, TUTS 59), 105 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
I have a 66 C-30, and want to improve the lighting. I've noticed that LMC, and a few other companies, have a headlamp relay/wire loom kit for adding halogen, or "Euro style" headlamps. Has anyone used one of these, and are they worth the money? Also I want to add cab lights.......looking for a style that would be close to what was available in the 60's. Any suggestions? Thanks!
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Riding in the Passing Lane
The relay system is great but I dont care for the Euro lights. Standard Haligens are just as good. You can make up the relay system yourself but at there price you wouldnt save much. I put the high 5 lights on some of my trucks like Jmoore linked to. They are available at LMC also. You can see them on my 70 with the link on the bottom of my post.
1972 Chevy c10 Cheyenne Super
Get a pair of these. Best lamp on the market, and will install with no modifications. I'm running them on both of mine and love them.
Bill Burmeister
Nice truck Wrenchbender! Those cab lights look great! I'm going to get some, as they look period correct. Longbox, are those headlights halogen? Why are they better than others? Thanks for the replies!
Yes, they are halogen. They put out a nice, clear, white light without being too harsh (like the hid/projector beams). They also have oe type lenses and mountings, so they are a direct replacement as far as fitment and aiming. They also work fine with the stock harness, no funky wiring/relays needed to make them work.
Bill Burmeister
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=0732700-R1-034-15A.jpg
http://s67.photobucket.com/albums/h298/1951otter/?action=view&current=2650080-R2-026-11A.jpg
installing a simple relay or two , one for high, one for low works a treat.
it's a simple job to wire one up
heck
even a single for hi/low is way better than the old days.
relays cost about $5-6bucks for everything you need as shown here plus a little wiring
http://alanhorvath.com/54chevy/headlight_relays.php
Jim & Caroline
If you turn on your lights & run a jumper wire from the bat. to the hot wire on the headlight socket you will see how much brighter they will be with a relay. That is what convinced me to put them on.
Longbox will those lights work in a 54 first series?
Disciple
If it's been converted to 12 volt, yes.
Bill Burmeister
I put halogen bulbs in the front of my 55 2nd. I bought/installed the harness from LMC. It was easy and I have had no problems.
Dennis
