1 members (homer52),
72
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,638 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | I have a 66 C-30, and want to improve the lighting. I've noticed that LMC, and a few other companies, have a headlamp relay/wire loom kit for adding halogen, or "Euro style" headlamps. Has anyone used one of these, and are they worth the money? Also I want to add cab lights.......looking for a style that would be close to what was available in the 60's. Any suggestions? Thanks! | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 |
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The relay system is great but I dont care for the Euro lights. Standard Haligens are just as good. You can make up the relay system yourself but at there price you wouldnt save much. I put the high 5 lights on some of my trucks like Jmoore linked to. They are available at LMC also. You can see them on my 70 with the link on the bottom of my post. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Get a pair of these. Best lamp on the market, and will install with no modifications. I'm running them on both of mine and love them.
Bill Burmeister | | | | | Joined: Nov 2008 Posts: 153 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 153 | Nice truck Wrenchbender! Those cab lights look great! I'm going to get some, as they look period correct. Longbox, are those headlights halogen? Why are they better than others? Thanks for the replies!
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, they are halogen. They put out a nice, clear, white light without being too harsh (like the hid/projector beams). They also have oe type lenses and mountings, so they are a direct replacement as far as fitment and aiming. They also work fine with the stock harness, no funky wiring/relays needed to make them work.
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 48 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you turn on your lights & run a jumper wire from the bat. to the hot wire on the headlight socket you will see how much brighter they will be with a relay. That is what convinced me to put them on. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | Longbox will those lights work in a 54 first series?
Disciple
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If it's been converted to 12 volt, yes.
Bill Burmeister | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I put halogen bulbs in the front of my 55 2nd. I bought/installed the harness from LMC. It was easy and I have had no problems.
Dennis -there is nothing stronger than the heart of a volunteer-
