1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
Any idea what this does? What is it called? On my 216, there is just a continuous hose connecting to the bottom of the radiator.
Nothing like this part. Is it necessary? What does it do? Thanks!
an image of the 235 part I am trying to identify
1946 Chevrolet 1/2-ton
More pix on Photobucket
Big Tee,
Can we guess? My guess would be some type of coolant filter or coolant conditioner. Let me know if I win a stuffed bear or little cardboard duck. smile
EDIT. Some '50-'54 rigs had a transmission oil cooler listed. Does that little thing have a couple of tube connections on the back side?
Stuart
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
I thought it might be an plug-in coolant heater...Joe
V
V Offline
I've never seen that before. Looks like a "catch all" to let the rust settle to the bottom of the system...
Any connections on the back side that I can't see? If so could it be a heat exchanger for an engine that may have run a pump?
Otherwise, I'm gonna be all wet.
i believe that is the transmission cooler for 53-54 powerglide equiped car. not sure what the 54 hydro trucks used, may be the same..
http://www.flickr.com/photos/11977495@N06/sets/
1952 COE
1952 3100
1953 3100
1950 6400
1951 Suburban
It is a 1950-54 Power glide trans. cooler.
H Online: Content
Ditto on the cooler. I've got a 1951 2-door hardtop in the shop now with one on it. If you don't want it, I'm interested.
I believe you all are correct and it is a powerglide trans cooler. See link as there are two threaded connections on the backside which I'm sure were an inlet/outlet.
The only strange thing is this is a non-pressure '53 235, so perhaps it was mated to a powerglide later on in life. Expect to see this part on e-bay in the not so distant future.
wink
Thanks as always! Stovebolters rock!
Big Tee
trans cooler other side
H Online: Content
From 50/51 to 53, the Powerglide-equipped cars ran the babbit-pounder 235's. I'm restoring the hardtop I mentioned for a colleague at school, and I desperately need one of those engines. Somebody has retro-fitted the car with a 216, which is not correct for it. Drop me a PM if the complete engine is available, please.
I have a '53 powerglide 235 that probably needs to be rebuilt
Socket Breaker
Socket Breaker
A trans cooler, neat.
-W
