1 members (Peggy M),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 140 | Hi fellow bolters, After some time searching for a good '48-53 COE cab I have finally found one and will be picking it up this weekend. I have also found an '83 dually as a donor for Chassis and running gear so you can tell I am intending to mount the COE cab onto the later model Chassis. (apologies to the purists) What I am looking for is a Body tag of 7700lb gvw reason being to keep this truck LHD I need to be able to register it here with a gvw of 7700lb or less otherwise I will need to convert it to RHD and that just ain't right. If anyone out there in stovebolt land can help out it would be greatly appreciated. Willy | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Try these folks... www.datatags.comI found them in the current issue of Generator & Distributor
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Wouldn't you need one for a 3/4 ton of that era? Wouldn't that raise a few eyebrows? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
