4 members (Hotrod Lincoln, Otto Skorzeny, Bill Hanlon, 1 invisible), 70 guests, and 1 robot.
Topics128,090
Posts1,056,026
Members48,432
#508696 02/21/2009 10:23 PM
It appears these units are prone to failure.
On my truck I took the unit out and it appeared the gears were stripped. On closer inspection I noticed that they were not stripped but the gear that drives the stainless windshield slide was able to move away from the drive gear. It appears when you move the gear to lower the windshield it wants to move that gear away from the drive gear. Over time this creates an oblong hole that allows the bolt that holds the window gear to move away from the drive gear.
I just found some scrap aluminum and cut a small shim and put it in the oblong hole to hold the gears tight. It worked like a charm.
Sorry I did not take photos. I hope this makes sense.
1942 Chevy 1/2-Ton Pickup
The Gallery story
Jeff's Blog
This one is a Tech tip. Tech tip link
Glad to see you figured this one out. I have to do the same this spring to mine.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Moderated by  ndkid275, Phak1
