| | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 69 'Bolter | | 'Bolter Joined: Jan 2009 Posts: 69 | It appears these units are prone to failure.
On my truck I took the unit out and it appeared the gears were stripped. On closer inspection I noticed that they were not stripped but the gear that drives the stainless windshield slide was able to move away from the drive gear. It appears when you move the gear to lower the windshield it wants to move that gear away from the drive gear. Over time this creates an oblong hole that allows the bolt that holds the window gear to move away from the drive gear.
I just found some scrap aluminum and cut a small shim and put it in the oblong hole to hold the gears tight. It worked like a charm.
Sorry I did not take photos. I hope this makes sense. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | This one is a Tech tip. Tech tip link Glad to see you figured this one out. I have to do the same this spring to mine.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
