| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50863 10/04/2005 4:56 PM | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | I was wondering if a Radiator out of a 1968 chevrolet pickup would fit in a 1966 chevrolet pickup. The 1968 has 350 and automatic transmission and the 1966 also has a 350 and A/T. Also, If I am using it as a daily driver do I need a 4 row or 2 row or does it matter. Thanks Brady | | |
#50864 10/04/2005 10:29 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Will it fit? You can make anything fit with a torch and a big hammer.
Will it bolt up with out modification. Probably not.
The 4 row will give you twice the cooling capacity. I wouldn't use a 2 row no matter what. | | |
#50865 10/04/2005 11:01 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | With a 350 and a/t, the factory used a 3 row. Add on a/c and they used a 4 row. The support for the 67-72 is different, but you should be able to adapt by using the newer mounts. You can buy them for a 3 row or 4 row. The 4 row in my 69 measures 19"T X 36"W X 2"D.
Some of the guys at the 67-72 board are using a 73-80 radiator. It's not quite as tall, and they say it's cheaper.
Fred 52 3600 69 C-10
#50866 10/06/2005 6:25 AM | Joined: Sep 2001 Posts: 78 Member | | Member Joined: Sep 2001 Posts: 78 | | | |
