2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
I was wondering if a Radiator out of a 1968 chevrolet pickup would fit in a 1966 chevrolet pickup. The 1968 has 350 and automatic transmission and the 1966 also has a 350 and A/T. Also, If I am using it as a daily driver do I need a 4 row or 2 row or does it matter.
Brady
Will it fit? You can make anything fit with a torch and a big hammer.
Will it bolt up with out modification. Probably not.
The 4 row will give you twice the cooling capacity. I wouldn't use a 2 row no matter what.
With a 350 and a/t, the factory used a 3 row. Add on a/c and they used a 4 row. The support for the 67-72 is different, but you should be able to adapt by using the newer mounts. You can buy them for a 3 row or 4 row. The 4 row in my 69 measures 19"T X 36"W X 2"D.
Some of the guys at the 67-72 board are using a 73-80 radiator. It's not quite as tall, and they say it's cheaper.
Fred
52 3600
69 C-10
Thanks Guys
