6 members (walter74, JW51, 3B, J Lucas, Joe H, 1 invisible), 86 guests, and 3 robots.
Topics128,080
Posts1,055,952
Members48,430
#499785 01/31/2009 1:00 AM
On the white plug that goes on the left side of the transmission, there are 3 wires coming out of a 4 prong plug.
Can someone tell me what each wire does for it's color?
tp://s367.photobucket.com/albums/oo113/RED64STEPSIDE/
On my 700R4 my wiring kit from American Auto Wire supplied a plug to that set of wires. I just plugged it in. If you need to know exactly what those wires go to I will check the schematic.
~Jim
It's going to depend on how your transmission is wired internally.
I have some Powerpoint slides I can send you that show how the TCI #37600 and the Bowtie Overdrives circuits are wired. If you have the stock GM harness inside the trans, I have some pictures of how the various way 80's Monte Carlos were wired that I could scan and send. It may be easier to just trace the wiring while you have the pan off. You are going to change the fluid and filter before putting a used trans into service, right?
regards,
Leon
Leon, yes. The filter & pan gasket was changed prior to installing in the truck. I left off some valuable info last night ( had been a long day! )
The transmission is from a 1987 1/2 ton chevy truck and was hooked up to a 350 motor. The plug I have a question about is the one on the outside of the trans. BUT, I found out last night after making this post, much to my anger & dismay, that someone in our shop has thrown that plug away!!!! IDIOTS!!!!! So NOW I have to go and get ANOTHER plug!
Any help any of you can offer would be GREATLY appreciated!!!!
Thanks guys!
Any of the FLAPS can get you a pigtail and plug.
What is the "FLAPS" ????????
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Favorite local auto parts store.......
OOOHHHHHHH. OK. LOL...
Having just gone through what you are experiencing, I can tell you that unless you are very fortunate, your "favorite local auto parts store" WON'T have the pigtail you are looking for--neither will your local transmission shop.
Try "700r4 connector pigtail" as your search term on evilbay and you should find one for less than $9.
BTW, you will find that there are 3 major valve body configurations and plus enough internal wiring combinations to drive you crazy. The least expensive alternative is if you have a functional #13 valve. Then you just have to replace that and place a suitable valve ball on the top of your solenoid and you don't even need to have the external wiring. I was not, however, so lucky.
So...I now have my Lokar TV cable installed and set and my new pigtail installed with plans to wire it to a hot to check out the lockup and then hopefully wire it to a transmission pressure switch for my 4th gear lockup.
If I were you, after locating a pigtail, I'd get a good transmission guy involved to make sure your TV cable is set and your lockup system is installed and working correctly.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
