1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 48 | On the white plug that goes on the left side of the transmission, there are 3 wires coming out of a 4 prong plug. Can someone tell me what each wire does for it's color?
tp://s367.photobucket.com/albums/oo113/RED64STEPSIDE/
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | On my 700R4 my wiring kit from American Auto Wire supplied a plug to that set of wires. I just plugged it in. If you need to know exactly what those wires go to I will check the schematic.
~Jim
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | It's going to depend on how your transmission is wired internally. I have some Powerpoint slides I can send you that show how the TCI #37600 and the Bowtie Overdrives circuits are wired. If you have the stock GM harness inside the trans, I have some pictures of how the various way 80's Monte Carlos were wired that I could scan and send. It may be easier to just trace the wiring while you have the pan off. You are going to change the fluid and filter before putting a used trans into service, right?
regards, Leon | | | | | Joined: Nov 2008 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 48 | Leon, yes. The filter & pan gasket was changed prior to installing in the truck. I left off some valuable info last night ( had been a long day! ) The transmission is from a 1987 1/2 ton chevy truck and was hooked up to a 350 motor. The plug I have a question about is the one on the outside of the trans. BUT, I found out last night after making this post, much to my anger & dismay, that someone in our shop has thrown that plug away!!!! IDIOTS!!!!! So NOW I have to go and get ANOTHER plug! Any help any of you can offer would be GREATLY appreciated!!!! Thanks guys!
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Any of the FLAPS can get you a pigtail and plug.
| | | | | Joined: Nov 2008 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 48 | Any of the FLAPS can get you a pigtail and plug. What is the "FLAPS" ????????
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Any of the FLAPS can get you a pigtail and plug. What is the "FLAPS" ???????? Favorite local auto parts store....... | | | | | Joined: Nov 2008 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 48 |
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Having just gone through what you are experiencing, I can tell you that unless you are very fortunate, your "favorite local auto parts store" WON'T have the pigtail you are looking for--neither will your local transmission shop.
Try "700r4 connector pigtail" as your search term on evilbay and you should find one for less than $9.
BTW, you will find that there are 3 major valve body configurations and plus enough internal wiring combinations to drive you crazy. The least expensive alternative is if you have a functional #13 valve. Then you just have to replace that and place a suitable valve ball on the top of your solenoid and you don't even need to have the external wiring. I was not, however, so lucky.
So...I now have my Lokar TV cable installed and set and my new pigtail installed with plans to wire it to a hot to check out the lockup and then hopefully wire it to a transmission pressure switch for my 4th gear lockup.
If I were you, after locating a pigtail, I'd get a good transmission guy involved to make sure your TV cable is set and your lockup system is installed and working correctly. | | |
