6 members (GMCJammer51, Gdads51, Joe H, Otto Skorzeny, DadsFirstPickup, Phak1), 99 guests, and 2 robots.
Topics128,056
Posts1,055,792
I've installed an S-10 T5 behind a '61 235 in a '41 1/2t PU. I'd like to retain the original e-brake lever but it bolts to the old tranny and I can figure how to mount it on the T5...Anybody used the old set-up in this scenario? Ideas, comment?
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
Steve - I'm getting ready to do the same thing in a '39. I think you have to fab a bracket for the e brake. How about the pedals and master cyl? What rear end did you use?
Junior Member
Junior Member
I have a 40 pu with an s10 T5. the e brake is hooked up and working. I didn't do that myself. I will look under and see if I can get a picture/discription of the install.
I've used a rear from a '79 Blazer 2WD w/ 3.42 rear. I'm looking at the Lokar floor mounted hand brake to see if it could possibly accept the old lever with some modification.
Steve G.
I'm also using the stock pedals...front discs and the Blazer drums in the back...had to fabricate a special bracket to accomplish this set-up with a rather long rod into master ('70 Chevelle master)
Steve G.
