2 members (Guitplayer, Achipmunk), 61 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#508413 02/21/2009 3:46 AM
Does any one Know about using the under floor brake booster and dual reservoir exhaust problems when installing the small block Chevy. I am not to this point yet but I am just researching it for future use.I am just getting started on the truck Thanks
Dunebuggy55
Depending on the transmission you will be using, the booster and MC may have to be moved to the rear to clear the trans. Not a problem if you can fabricate the brackets.
Lonnie, what you are saying is move it to the rear of the cab along the frame and connect it with a push rod? Thanks
Dunebuggy55
Yes; you will see the same thing with some of the early hotrods, where the trans interferes with the MC and booster.
There are some other options for boosters besides vacuum type. Do a search on some of the hotrod sites and you will get some ideas.
Basically though, you just need to move it straight back until it clears and build a mount for it.
Chuck... I bought one with a 7" dual diaphram servo,it gives you a little more clearance although I have heard that some folks have had problems usung a manual trans.
As you can see I had to off-set my X-member (A lack of foresight on my part!) but had no clearance issues with the booster itself.
It's a TH350 trans BTW.
Mine was from Master Power Brakes.
I hope this helps
Jock thumbs_up
More pix on Flickr.
i also used master power brakesand have a 350/350 only issue i had was i had to notch my trans mount (chassis engineering )to clear the master cyclinder. and had i used a different style mount it would have been fine..................dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
I prefer the clean look on the firewall. It's not much trouble to keep it under the cab. It's no trouble if you'll be running an auto tranny. Most vendors sell kits for that adaption
~Jim
I am running a 350 engine and 700R4 tranny,with an under the floor dual MC. No problems.Oh yeah thats in a 55 2nd series.
I am the same as dale, except a 53 chevy half/ton, no problems at all. Didn't need to alter anything also!
Thanks for all the input bolters. I want to keep it under the floor for better appearance under the hood.
Chuck
Dunebuggy55
