| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 11 New Guy | | New Guy Joined: Nov 2008 Posts: 11 | Does any one Know about using the under floor brake booster and dual reservoir exhaust problems when installing the small block Chevy. I am not to this point yet but I am just researching it for future use.I am just getting started on the truck Thanks
Dunebuggy55
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Depending on the transmission you will be using, the booster and MC may have to be moved to the rear to clear the trans. Not a problem if you can fabricate the brackets. | | | | | Joined: Nov 2008 Posts: 11 New Guy | | New Guy Joined: Nov 2008 Posts: 11 | Lonnie, what you are saying is move it to the rear of the cab along the frame and connect it with a push rod? Thanks
Dunebuggy55
| | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | Yes; you will see the same thing with some of the early hotrods, where the trans interferes with the MC and booster.
There are some other options for boosters besides vacuum type. Do a search on some of the hotrod sites and you will get some ideas.
Basically though, you just need to move it straight back until it clears and build a mount for it. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Chuck... I bought one with a 7" dual diaphram servo,it gives you a little more clearance although I have heard that some folks have had problems usung a manual trans. As you can see I had to off-set my X-member (A lack of foresight on my part!) but had no clearance issues with the booster itself. It's a TH350 trans BTW. Mine was from Master Power Brakes. I hope this helps Jock
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i also used master power brakesand have a 350/350 only issue i had was i had to notch my trans mount (chassis engineering )to clear the master cyclinder. and had i used a different style mount it would have been fine..................dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I prefer the clean look on the firewall. It's not much trouble to keep it under the cab. It's no trouble if you'll be running an auto tranny. Most vendors sell kits for that adaption
~Jim
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I am running a 350 engine and 700R4 tranny,with an under the floor dual MC. No problems.Oh yeah thats in a 55 2nd series.
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I am the same as dale, except a 53 chevy half/ton, no problems at all. Didn't need to alter anything also! | | | | | Joined: Nov 2008 Posts: 11 New Guy | | New Guy Joined: Nov 2008 Posts: 11 | Thanks for all the input bolters. I want to keep it under the floor for better appearance under the hood. Chuck
Dunebuggy55
