| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50850 10/04/2005 5:45 AM | Joined: Oct 2005 Posts: 2 Junior Member | | Junior Member Joined: Oct 2005 Posts: 2 | Is it possible to put a carrier out of a 70's model 12-bolt into a 60's model 12-bolt and vice-versa? :confused:
Im thinking the splines on the side gears might be different, but can they be swapped out?
Thanks...
NEVER GONNA STOP!!
#50851 10/04/2005 11:57 AM | Joined: May 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 50 | The truck 12 bolts are different from car ones. You would have to change the side gears in the posi unit if the splines were different...I have never had any luck trying to piece something together. A used posi unit at a swap meet should be around $200 . Make sure you get the right one though as there are many 12 bolts out there : Chevy car, Chevy truck, Oldsmobile, and variations thereof including 2, 3, and 4 series carriers.
Dave
Even a blind squirrel gets a nut sometimes!
#50852 10/04/2005 8:25 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I read recently that Eaton is now manufacturing their posi carrier's with a new type of clutches that last longer. So, you might be able to buy one that fits right without having to search.
Truck and car 12 bolts are different.
Have you looked on e-bay? Try searching for '12 bolt posi', you'll be surprised what you find from shim packs, ring and pinions all the way to completely rebuilt 12 bolts with heavy duty axels and c-clip elminators.
