| | | Forums66 Topics128,195 Posts1,057,373 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | There are a number of pages that come up, from search, when I look for wiring harnesses. I hope I can save myself some time by asking what is recommended.
Although most of the original wiring still exists, the only things hooked up are a 12 volt single wire alternator, a 12 volt battery and the ignition switch with a ballast resistor for the coil.
The truck runs, but, since I don't know how much 12 volt conversion was done by the PO, I'd rather replace everything.
Cost is an issue, and I don't plan to add any new electrical equipment. (No 500 MegaWatt thunderbox.) ;}
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Classic Parts of America has an excellent harness at a reasonable price. It is not cloth covered (like the original). The harnesses are different for different years. They provide extra wire for turn signals, dual tail lights, and longer body trucks. http://www.classicparts.com/1950-52-Wiring-Harness-Alternator/productinfo/52-024/ | | | | | Joined: Apr 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 127 | I just wired my 37 with a harness and fuse block from Rebel Wire. Nice quality and labeled every 6 inches. The basic 9 + 3 circuit was $130.
Just because you have a few Craftsman tools, it dosen't mean your a craftsman.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Spend some time to compare prices between kits that are complete originals and those that are generic to trucks. While the originals might be a little easier to install the generic might be cheaper and afford more upgrade possibilities. Personally I like the fuse panel under the dash.
~Jim
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | I just wired my 37 with a harness and fuse block from Rebel Wire. Nice quality and labeled every 6 inches. The basic 9 + 3 circuit was $130. Rebel Wire has basic harness kits built by hand (in America with American components) - 10% discount for Stovebolters / 15% discount for Stovebolt Supporters. Must call after 5 pm Central Time to request discount. | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I'm not too concerned about originality. There's no way to resto this combination of parts. (different years of engine, cab and chassis) I would like to have a fuse block, though. Does the Classic Parts harness have one? I'm probably going to need a few extra circuits for legal reasons. Right now it has fender mounted front turn signals and three lights mounted to the rear frame under the dump bed. I don't think those will pass inspection.
