6 members (Samantha, tclederman, TUTS 59, Otto Skorzeny, Mike Roache, Steelonsteel), 48 guests, and 4 robots.
Topics128,036
Posts1,055,458
Members48,422
#507716 02/19/2009 12:48 PM
Crazy question but. why are there so many different looking valve covers? I found a much nicer one than I had and swapped out to it, and the screw holes etc. match, but the filler hole is in a different place. is this is big deal? I dont see any interferences etc. also the one I got rid of had a tap in the side w/ a 3 inch rubber hose hanging out of it that was plugged, this one does not. the other one didnt seem to be being used.
56 stepside 3/4 ton longbed
56
Over the years i've noticed that the location of the oil filler hole appears to have been determined by year of the engine be it a 236 or 261. The hole on the side of the cover can only be for a pvc valve/hose to the intake. So long as the holes line up and your ok with the location of the oil filler hole be happy.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
hi 52, just wondered if the changed lcoation of the filler hole and the cap would hit something down in there. my old cover had the center fill hole and the new one is on the middle, caps are the same, so no worries?
No worries. However, the PCV hole on the side of the valve cover should be covered/plugged (if you do not have a PCV).
Here is a pic of all the valve covers used on 216, 235, and 261's
http://picasaweb.google.com/pre68bowtie/MechanicalPart#5048988120830487474
My Blog
That is most excellent, Dave. Thanks.
Ex Hall Monitor
Ex Hall Monitor
Ditto the thanks. The one on the bottom is the one on my 38.
Pre 68,
Thats a great list, thanks. The changed location of the valve cover oil fill hole will not cause a problem. Try hooking up the valve cover to a pvc valve and tee into your intake manifold. You may have to retune your air fuel screw on the carb and possibly the timing if you are sucking oil fumes.
