| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | Crazy question but. why are there so many different looking valve covers? I found a much nicer one than I had and swapped out to it, and the screw holes etc. match, but the filler hole is in a different place. is this is big deal? I dont see any interferences etc. also the one I got rid of had a tap in the side w/ a 3 inch rubber hose hanging out of it that was plugged, this one does not. the other one didnt seem to be being used.
56 stepside 3/4 ton longbed
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | 56 Over the years i've noticed that the location of the oil filler hole appears to have been determined by year of the engine be it a 236 or 261. The hole on the side of the cover can only be for a pvc valve/hose to the intake. So long as the holes line up and your ok with the location of the oil filler hole be happy.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
| | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | hi 52, just wondered if the changed lcoation of the filler hole and the cap would hit something down in there. my old cover had the center fill hole and the new one is on the middle, caps are the same, so no worries?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No worries. However, the PCV hole on the side of the valve cover should be covered/plugged (if you do not have a PCV).
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | That is most excellent, Dave. Thanks.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Ditto the thanks. The one on the bottom is the one on my 38.
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Pre 68,
Thats a great list, thanks. The changed location of the valve cover oil fill hole will not cause a problem. Try hooking up the valve cover to a pvc valve and tee into your intake manifold. You may have to retune your air fuel screw on the carb and possibly the timing if you are sucking oil fumes.
