2 members (crenwelge, 1 invisible),
181
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | One of the axle seals on my '54 1-1/2 ton blew out resulting in a saturation of gear oil on my passenger rear brake shoes. How do I get this oil out of them? I was told that steaming them does the trick haven't tried that yet. Are there any other tricks out there to curing this problem? | | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | We clean shoes at work with a good degreaser and the hot power washer. If they haven't been soaking in the oil for years, it should come out. Spray type Brake Clean works really well also. Change them out if they are really bad. If the inside of the drum is polished smooth, the shoes are most likely to oil soaked. Give it a try if been just a day or two. Joe | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | For safety sake I'd change them out once your seal problem is fixed. Price of new shoes is cheap insurance. You need to address the drum also.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | unless they are real hard to find ,or money is the problem replace them . on a old Harley sportster i had the drum brakes were soaked with grease for a long time ,i just washed them with brake clean to get the majority of the oil off and used a heat gun to drive any grease out ,had to heat and wipe them several time's . | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Replace them. Once any kind of oil (or even brake fluid) gets into the friction, the shoes are junk. There is no way to 100% get it all out.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,964 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,964 | I have been in the trucking business 45 years. In the early years I tried to salvage brake linings, but it just isn't worth it. A brake pad that has absorbed any type of oil will always grab before the rest of them which can lead to a dangerous situation. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | |
