8 members (mvigo, Charles in CA, Rusted Nut, UtahYork, Peggy M, Shade Baby, klhansen, 1 invisible),
80
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | My heater valve is leaking on my 58 gmc. Is the only option to replace it with a new one? I do not think that I need the thermostatically controlled valve like the one that is there now. I was thinking of a plumbing valve under the hood for the little amount I would need it. Is there after market valve from NAPA that could be used that would have the mount for the cable and be installed in the heater box? Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If the valve is leaking due to a bad seal, this might help. | | | | | Joined: Mar 2005 Posts: 94 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 94 | But I hear they're a bugger to rebuild. take a look here: http://www.pbase.com/czechman/ranco
1953 Chevrolet 3100
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you could also get this kind of valve, cable operated for temp control [prolly at NAPA], and keep the potential leaks outta the cab  Bill | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Indeed... If I were you, I'd just send the thing in for rebuilding. It's just not worth the effort. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | you could also get this kind of valve, cable operated for temp control [prolly at NAPA], and keep the potential leaks outta the cab  I've tried in vain several times to find that same valve. If anyone has a source for it, I'd really appreciate it. | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | you could also get this kind of valve, cable operated for temp control [prolly at NAPA], and keep the potential leaks outta the cab  I've tried in vain several times to find that same valve. If anyone has a source for it, I'd really appreciate it. I would also like to find something like that! | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Look up Item#: BK 6601140 at napas online site. This heater control valve fits 1972-1980 International scout.
Get on ebay and do a search on heater control valve,this will give you an idea what types are available.There are some Volkswagen heater control valves that look similar. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you could also get this kind of valve, cable operated for temp control [prolly at NAPA], and keep the potential leaks outta the cab  I've tried in vain several times to find that same valve. If anyone has a source for it, I'd really appreciate it. I would also like to find something like that! oooh! I see a get rich scheme appearing!  I'll get the part number/source next time I talk to the guy, I'm sure it's off the shelf local, don't turn blue, might not be til next week  for the TF trucks [Chevy anyway, maybe GMC], an exact replacement comes from older Volvos, but I prefer a simpler manual control under the hood Bill | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | Bowtietim is correct. One of the guys I work with bought a valve like that for his 59 just a couple of weeks ago. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, what they said - it's close enoughBill | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | As long as it has holes or brackets that can be mounted to the inner fender and provisions for a cable I'll be happy. I'd just as soon bypass my Ranco and get it over with. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | they don't have mounting provisions built on, they're positioned by the hose they clamp into, so you could attach the hose either side of the valve, but it's not necessary, the one I linked above on my buddy's panel truck never moves, works slick
Bill | | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | if you want to repair the original, classic parts(KC MO) will rebuild yours, takes a few days, bowtie bits(wichita ks), will either rebuild yours, or swap you your core for a new one. I have actually worked with both, and had success with both. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | they don't have mounting provisions built on, they're positioned by the hose they clamp into, so you could attach the hose either side of the valve, but it's not necessary, the one I linked above on my buddy's panel truck never moves, works slick Bill Just to be sure... Just put the hoses on, attach the cable and it works so smoothly that you don't have to secure it to anything? That's cool if it does. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | exactly, the cable operation is quite smooth and effortless
Bill | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Thanks Bill...
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I just bought one from Jim Carters...will be putting it back together this week...(Deluxe heater) | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | I found one at the Volvo mack truck dealer for $25 seems to work good 5/8" | | |
