1 members (Sjm), 149 guests, and 5 robots.
Topics128,266
Posts1,058,385
Members48,485
#505541 02/13/2009 1:24 PM
My heater valve is leaking on my 58 gmc. Is the only option to replace it with a new one? I do not think that I need the thermostatically controlled valve like the one that is there now.
I was thinking of a plumbing valve under the hood for the little amount I would need it.
Is there after market valve from NAPA that could be used that would have the mount for the cable and be installed in the heater box?
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
If the valve is leaking due to a bad seal, this might help.
But I hear they're a bugger to rebuild.
take a look here: http://www.pbase.com/czechman/ranco
1953 Chevrolet 3100
you could also get this kind of valve, cable operated for temp control [prolly at NAPA], and keep the potential leaks outta the cab grin
Indeed... If I were you, I'd just send the thing in for rebuilding. It's just not worth the effort.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
I've tried in vain several times to find that same valve. If anyone has a source for it, I'd really appreciate it.
Woody
Door Art Collection
I would also like to find something like that!
Regards,
Lindsay
Look up Item#: BK 6601140 at napas online site.
This heater control valve fits 1972-1980 International scout.
Get on ebay and do a search on heater control valve,this will give you an idea what types are available.There are some Volkswagen heater control valves that look similar.
1951 3100 Chevrolet
oooh! I see a get rich scheme appearing! grin I'll get the part number/source next time I talk to the guy, I'm sure it's off the shelf local, don't turn blue, might not be til next week thumbs_up
for the TF trucks [Chevy anyway, maybe GMC], an exact replacement comes from older Volvos, but I prefer a simpler manual control under the hood
Bowtietim is correct. One of the guys I work with bought a valve like that for his 59 just a couple of weeks ago.
yeah, what they said - it's close enough
As long as it has holes or brackets that can be mounted to the inner fender and provisions for a cable I'll be happy. I'd just as soon bypass my Ranco and get it over with.
Woody
Door Art Collection
they don't have mounting provisions built on, they're positioned by the hose they clamp into, so you could attach the hose either side of the valve, but it's not necessary, the one I linked above on my buddy's panel truck never moves, works slick
Y
Y Offline
if you want to repair the original, classic parts(KC MO) will rebuild yours, takes a few days, bowtie bits(wichita ks), will either rebuild yours, or swap you your core for a new one. I have actually worked with both, and had success with both.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
they don't have mounting provisions built on, they're positioned by the hose they clamp into, so you could attach the hose either side of the valve, but it's not necessary, the one I linked above on my buddy's panel truck never moves, works slick Bill
Just to be sure... Just put the hoses on, attach the cable and it works so smoothly that you don't have to secure it to anything? That's cool if it does.
Woody
Door Art Collection
exactly, the cable operation is quite smooth and effortless
Thanks Bill... grin
Woody
Door Art Collection
I just bought one from Jim Carters...will be putting it back together this week...(Deluxe heater)
GMC: Get More Cash...
1958 GMC
My Webshots photos
I found one at the Volvo mack truck dealer for $25 seems to work good 5/8"
Regards,
Lindsay
