| | | Forums66 Topics128,050 Posts1,055,749 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | How in blue blazes do you install the vent flaps on a '57 1/2 ton.I laid on my back on the floor and had NOOOOOOOO luck.Am i missing a trick or is just perseverance that is gonna get me thru!  Thanks,roy | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you mean the rubber seal on the kick panel vent doors .... take the metal doors out and work on the bench  Bill | | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | hi red,i got the doors out put the new rubbers on,just can not get the doors back in.Is there a trick to it?  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | can't recall exactly, but I'm sure it was a struggle because the seals make it a tight fit  either top or bottom peg first, and the seals 'fold' opposite sides, in the direction of movement ... you need to put the piece in and attach the cable end after, and a bit of light rubber lube will help Bill | | |
