Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
11 members (Gib70, TooMany2count, niobrarafun, RBs36, 2-Ton, Charles in CA, Wally / Montana, TUTS 59, Shaffer's1950, JW51, 46 Texaco), 545 guests, and 1 robot.
Topics126,776
Posts1,039,277
Members48,100
Most Online2,175
Jul 21st, 2025
#505466 02/13/2009 5:11 AM
How in blue blazes do you install the vent flaps on a '57 1/2 ton.I laid on my back on the floor and had NOOOOOOOO luck.Am i missing a trick or is just perseverance that is gonna get me thru! frown
Thanks,roy
One ear dicky #505485 02/13/2009 5:57 AM
if you mean the rubber seal on the kick panel vent doors .... take the metal doors out and work on the bench grin
Flxible #505665 02/13/2009 10:07 PM
hi red,i got the doors out put the new rubbers on,just can not get the doors back in.Is there a trick to it? headscratch
One ear dicky #505678 02/13/2009 11:10 PM
can't recall exactly, but I'm sure it was a struggle because the seals make it a tight fit ohwell either top or bottom peg first, and the seals 'fold' opposite sides, in the direction of movement ... you need to put the piece in and attach the cable end after, and a bit of light rubber lube will help
Moderated by  ndkid275, Phak1
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.225s Queries: 14 (0.027s) Memory: 0.6069 MB (Peak: 0.6447 MB) Data Comp: Zlib Server Time: 2025-09-22 16:30:00 UTC
Valid HTML 5 and Valid CSS
