| | | Forums66 Topics128,193 Posts1,057,360 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 57 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 57 | Can anyone let me know how easy is it to switch from a 6 lug to a 5 lug rear axle on my 1/2 ton 54 I believe I have a 70's rear end but am not sure of the exact one. Reason is I put in a Mustang 2 / 5 lug front end in. Shops I have checked quoted me just under 500 smackers. Seems like a lot of mulah. Thanx
Try prayer as the first response rather than a last resort ...
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | the axle change isn't all that hard you just have to make sure you have the right size on this site there is a chart for complete messurments other than that it will just be a matter of matching spring perches to springs and you can get most perchs/shackles/springs from aftermarket sources fairly easy or if you have a good u-pull-it type salvage yard hand even better
1937 1/2 ton
| | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | You can actually have the current axles and drums plugged and re-drilled and you don't have to worry about changing anything else. Moser Engineering in Portland Indiana will do it and it's not all that expensive. http://www.moserengineering.com/Pages/contact.html | | |
