3 members (Gib70, cmayna, baldeagle), 117 guests, and 1 robot.
Topics128,113
Posts1,056,613
Members48,450
so im in the process of rebuilding my carter yf. a friend of mine suggested that after i take it all apart that i sandblast it all and then dip it in the carb. cleaner acid and after that blow air through everything. ifeel a little hesitant in doing this. is this a common practise im just not familiar with or is it just a really bad idea?
Murdoc,
I agree with you...that is real FISHY!! A good tank of carb cleaner will take everything off and out, including your skin. I would think your friend actually meant glass beading as opposed to sand blasting. The carb body is pot metal and the glass can embed itself in the
material quite easily. I don't think this is common pratice among rebuilders, but I have been known to be wrong quite often.
Stuart.
I blasted (using either glass bead or aluminum oxide - I can't remember which) an old Zenith updraft carb for my dad's Fjord AA. There was so much gunk and surface rust on it that it went through a treatment of blast, soak in carb cleaner, dry, repeat for a few weeks before it was completely clean. After three or four rounds of that, and a fresh powder coating job and a rebuit kit, it runs great.
1954 GMC De Luxe COE
The only way I would blast die cast is with plastic media or walnut shells, anything stronger will do damage.
Not recommended for all the reasons stated above, and the fact that you will remove any finish the carburetor has left. Buy the gallon can of carb cleaner and place the disassembled carb in it to soak overnight, at least. Then take a nylon brush with stiff bristles (the GI toothbrush for cleaning guns is what I use) and start scrubbing. Scrub some, soak it again, and continue until it's clean.
Fred
52 3600
69 C-10
I own a small metal refinishing business on the side. I would try all the soaking and brushing tricks first. If all else fails, take it to a pro who uses hulls or soda ash as a blast media.
sweet great input guys, i was pretty sure it wasnt a good idea. ill start the rebuild tomarrow
You can soak it in lye for several weeks without damaging the metal. That will remove all the grease and varnish, and it's better for your lungs. Just don't get it on your skin.
Paint & Body Shop moderator
