1 members (klhansen), 70 guests, and 3 robots.
Topics128,094
Posts1,056,064
Members48,433
#504715 02/11/2009 12:56 PM
I have a chance to pick up some parts on a 1941 chevy truck. The only problem is I believe its a one ton where mine is only a half ton. Mine is also a 1946. In the pictures it looks like the same truck. Is it?
I think you will find that most of the cab parts are interchangeable from the 1 ton to the 1/2 ton. The fenders are going to be different so they won't be of use to you. I think that the hood and grill are the same also.
As for the engine. It could be usefull, but the drive line and brakes will be different.
Hope this helps
George
46forme #505331 02/12/2009 11:59 PM
The rear window is different for the '41 vs the '46 as well
That is a model change not a 1/2 ton vs 1 ton issue.
Also the door locks for a '41 is in the handle - '42 and up is in the door
There were no 1 tons for '41, exept for the Special Panel, whcih was more of a downgrded 1 1/2 ton.
Bill Burmeister
Moderated by  ndkid275, Phak1
