2 members (tclederman, tesa),
56
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,024 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 17 New Guy | | New Guy Joined: Jun 2008 Posts: 17 | I have a chance to pick up some parts on a 1941 chevy truck. The only problem is I believe its a one ton where mine is only a half ton. Mine is also a 1946. In the pictures it looks like the same truck. Is it? | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I think you will find that most of the cab parts are interchangeable from the 1 ton to the 1/2 ton. The fenders are going to be different so they won't be of use to you. I think that the hood and grill are the same also. As for the engine. It could be usefull, but the drive line and brakes will be different. Hope this helps George | | | | | Joined: Jun 2008 Posts: 106 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 106 | The rear window is different for the '41 vs the '46 as well That is a model change not a 1/2 ton vs 1 ton issue. Also the door locks for a '41 is in the handle - '42 and up is in the door
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | There were no 1 tons for '41, exept for the Special Panel, whcih was more of a downgrded 1 1/2 ton.
Bill Burmeister | | |
