8 members (Bill Hanlon, Otto Skorzeny, Maybellene, 2-Ton, klhansen, carbking, Peggy M, Wayne67vert),
68
Mod | | | Forums66 Topics128,042 Posts1,055,497 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 51 | Hi,
does somebody know if a front axle (bare I-beam) from a 56 1/2 ton Chevy Truck fits in a 55 1st serie 1/2 Truck.
I like to swap just the axle, that means I like to leave the original king-pin, leaves, shocks and spindels of that 55 Truck.
If not, what makes it not fit? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'm pretty sure the answer is that it does not fit, and the reason is differences in how the springs are set up.
You might be able to modify it to work, but its not just a bolt on operation.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Bernd and guys, I could not find a front track specification for the 55-59, but I know the frame of a 55A and older truck is tapered, where the 55-59 frame rails are parallel, so the minimum you would have to do is redrill the "U" bolt holes in the axle. Also the kingpins appear to be different in some way, Carters list a different p/n for the two axles, I would say this is not an easy conversion to do. | | | | | Joined: Apr 2006 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 51 | Thanks for the info, that means I have to keep looking for the right one. I'm here in Germany and it is not as easy to get hold of an axle.
Does an axle from 47-53 Truck fit in a 55-1st serie Truck or has there also changed something?
| | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | Bernd, This guy had some front axles for sale recently. http://www.dannyschevyparts.co.uk/I know it's not in Germany, but it's a lot nearer to you than the US. Stuart. | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | The axle from the 56 is wider than the AD axle. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Bernd, the axle should be the same from 47-55 1st or "A" series | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3B, am I reading it correctly : 1941-1955-1st series 1/2 ton axles are all interchangeable? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy tclederman and guys, that is not what I typed, but I thought I should do some more research and low and behold 41-55A 1/2ton front axles are the same p/n 3656872, hope that clarifies | | |
