6 members (NJC, Southerntruck, baldeagle, Ponchogl, Eisenholtz, Otto Skorzeny), 208 guests, and 2 robots.
Topics128,037
Posts1,055,468
Members48,424
#504885 02/11/2009 8:49 PM
Hi,
does somebody know if a front axle (bare I-beam) from a 56 1/2 ton Chevy Truck fits in a 55 1st serie 1/2 Truck.
I like to swap just the axle, that means I like to leave the original king-pin, leaves, shocks and spindels of that 55 Truck.
If not, what makes it not fit?
I'm pretty sure the answer is that it does not fit, and the reason is differences in how the springs are set up.
You might be able to modify it to work, but its not just a bolt on operation.
They are not the same part number but maybe someone knows if you could use it.
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0522.htm
3B Offline
Hy Bernd and guys, I could not find a front track specification for the 55-59, but I know the frame of a 55A and older truck is tapered, where the 55-59 frame rails are parallel, so the minimum you would have to do is redrill the "U" bolt holes in the axle. Also the kingpins appear to be different in some way, Carters list a different p/n for the two axles, I would say this is not an easy conversion to do.
3B #505147 02/12/2009 10:12 AM
Thanks for the info, that means I have to keep looking for the right one. I'm here in Germany and it is not as easy to get hold of an axle.
Does an axle from 47-53 Truck fit in a 55-1st serie Truck or has there also changed something?
Bernd #505149 02/12/2009 10:18 AM
Bernd,
This guy had some front axles for sale recently.
http://www.dannyschevyparts.co.uk/
I know it's not in Germany, but it's a lot nearer to you than the US.
Stuart.
The axle from the 56 is wider than the AD axle.
3B Offline
Hy Bernd, the axle should be the same from 47-55 1st or "A" series
3B #505298 02/12/2009 10:37 PM
3B, am I reading it correctly : 1941-1955-1st series 1/2 ton axles are all interchangeable?
3B Offline
Hy tclederman and guys, that is not what I typed, but I thought I should do some more research and low and behold 41-55A 1/2ton front axles are the same p/n 3656872, hope that clarifies
