| | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50502 09/25/2005 1:06 PM | Joined: Sep 2005 Posts: 5 Junior Member | | Junior Member Joined: Sep 2005 Posts: 5 | hey guys, I am new to this rodding stuff. I just bought a 1950 chevy truck. I want to find out what v8 engine, trans and rearend will fit this truck. I do not want to modify extensivly, but I do know that some work will need to be done.I want to go v8 and make it a nice truck. any info on the combo will be appreciated greatly! | | |
#50503 09/25/2005 2:00 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Mine is a 55 2nd series.I am running a 350 Chevy engine,700R4 tranny,and stock 3:90 rear.It is one sweet ride.The 350 and 700R4 will fit in just about anything including your 50.As far as rearends go you will have to change it out if it has the stock rear in it,due to the closed driveshaft setup.There are many aftermarket motor mounts,trans.mounts ,etc.for these swaps.I dont know what rears will fit up to your 50,for tire clearance,etc.A couple guys around here are running Ford 9 inch rears in their ADs.If you use the 700R4 which is an overdrive tranny,you can run 3:90s,or even 4;11s.If you go with a 350 or 400 turbo,I would think 3:42s,or 3:08s would be a good ratio. | | |
#50504 09/25/2005 2:14 PM | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Chevy 50,
The easiest rear end swap for you would be to get a 1955 1st series rear end. This is an open drive shaft rear end and can be used with whatever engine trans combo you pick. The 1955 1st is a bolt in replacement. Before that it was closed drive shaft (Torque tube) and after that the spring perches are different.
The only problem with the 1955 1st series is it was only a 6 month poduction run and they are getting harder to find.
If you don't mind welding on spring perches, you can buy an axle swapping kit from places like cpp and put just about anything back there.
The 1955 1st is a 3.90 rear end.
Bill Schickling | | |
#50505 09/25/2005 4:48 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I always want to ask what a 'nice truck' means to you. For some guys that's a trophy winning show truck, for others its a truck that is pleasant to drive every day, and for others its something different or inbetween.
As you listen to responses remember the guy answering may have a different idea of nice truck than what you do.
I think you'll be happier with the outcome if you've spent a little time thinking about how you'll use the truck, how much work you are willing or able to do yourself, and how much money you can or are willing to spend.
While you can shoehorn a Chevy smallblock under the hood with little prep, you will find a few issues make it more complicated. The steering column and box are where your exhaust manifold wants to be. The crossmember holding up the rear of the motor (under the bellhousing) will interfere with almost any automatic transmission. That's the first two that come to mind, there are others.
More important is that more power is likely to mean more speed. The aged stock brakes were not designed for the speeds the truck will now be capable of.
I'd suggest taking a few minutes to write down how you want to use the truck, and then think through how that impacts the various systems. Then turn that into a plan.
Last time I went through this exercise I dropped some of my ideas because the truck was getting too expensive. But now when I see something at a swap meet, I know if it fits the plan and budget or not.
When I see something cool that doesn't fit the plan I like to buy it anyway and set it aside for the next project. Seems to work well for me, I have five projects and have found a candidate for number six...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#50506 09/25/2005 5:44 PM | Joined: Mar 2005 Posts: 49 Member | | Member Joined: Mar 2005 Posts: 49 | Great advice Steve. Too often restorers will collect a bunch of parts without a total plan. Look at the big picture and determain if it is within you're ability range and budget before proceeding otherwise your project will never get finished. A very nice driver which can be accomplished with minimal expense is a 235 engine and a Patricks 3.55 rear. If you want to spend another $1000 you could add a Saginaw 4 speed trans. | | |
#50507 09/25/2005 10:16 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I remember when Saginaw 4-speeds were hard to give away...
Patricks wants $300 or so for the shifter and the kit to make it work with a torque tube is more. I'd probably choose then to swap to open drive rather than re-gearing the original.
That does sound like a nice driver.
#50508 09/26/2005 1:00 AM | Joined: Sep 2005 Posts: 5 Junior Member | | Junior Member Joined: Sep 2005 Posts: 5 | hey guys, thanks for all the info so far! I would like to know what type of rear ends will fit under the 50 and still run with the traffic, 70 or 75 mph. also could anyone tell me what will be invovled with putting a v8 in this truck.this will not be a show truck. thanks in advance!! | | |
#50509 09/26/2005 1:36 AM | Joined: Mar 2000 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2000 Posts: 73 | Here is one more option. In my 46 1/2 ton I swapped out the center pumpkin for one from an open driveline 56 1/2 ton. The pumpkin will bolt right in to the old housing. I then welded in new solid type spring perches. It worked good for me because I kept my old housing and the e-brake stayed. I also kept 6 lug all around. The pumpkin from the 56 had 3:38 gears. I'm running a 283 with a TH350 and it has held up fine so far. | | |
#50510 09/26/2005 1:52 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Running 70-75 does not require a V-8. You need to start with the size tires you want to run, then choose rear gears that will allow you to run that speed at a comfortable engine RPM.
I have the rear from a '73 Chevelle wagon with 3.08 gears under mine. I can easily run 75+ with my six. A V-8 would easily do the same with those gears.
#50511 09/29/2005 8:18 PM | Joined: Sep 2005 Posts: 2 Junior Member | | Junior Member Joined: Sep 2005 Posts: 2 | I am pretty new to the 47 to 54 trucks so this might sound like a dumb question-- how fast does the engine, trany and suspension on a stock truck let you go down the highway comfortably? | | |
#50512 09/29/2005 8:47 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Curly,
That again would depend alot on the gearing in the rear-end.
You didn't mention what type of truck you had, whether it's a 1/2 ton or bigger. The 3/4 ton and larger had different gears, and would result in slower speeds.
There also seems to be a difference in results between a stocck 216 and a stock 235.
My stock 52, (235) with 4:11 gears will run pretty comfortably between 50 - 55ish.
My stock 46, (216) with the same rear-end is pretty comfortable just under 50.
My other 52, with a 250 I-6 and stock 4:11's will run between 55-60.
These are all 1/2 tons, and have the same gearing, but each one has a different motor type. There's not a significant difference between them but there is some. | | |
#50513 09/29/2005 10:09 PM | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Don't they make a gear swap for the rear end?
I seem to remember reading somebody sold a kit you can put in the exsisting rear end to give you better "top" speeds.
#50514 09/29/2005 11:09 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Fumblin,
Probably the most common conversion is sold by Patrick's. It will take you down to a 3:55 and supposedly allows you to run highway speeds at a comfortable RPM.
If I remember correctly, the ring and pinion run about $400.00. Another $300.00 for their installation kit.
A recent thread suggests that while it isn't real difficult, it should not be undertaken by your average backyard mechanic. There are also some special tools/equipment required. | | |
