2 members (klhansen, Peggy M), 167 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#504884 02/11/2009 8:48 PM
I am looking at a GMC,its a '71-'75,I spoke to the owner on the phone,he's not sure the year exactly or the model and he's on the road at the moment.Its a V-6 Gas with air brakes and tandem axle.I have researched all morning and haven't found much info,does anyone know anything about these ? [IMG]http://i210.photobucket.com/al...c3oaZZZZZZZZZ929db5c7af699c217.jpg[/IMG]
'57 GMC F350
'49 VW
'62 Mercedes Benz L319d panel van
barndoor #504904 02/11/2009 9:57 PM
Riding in the Passing Lane
I'm not sure what you want to know. They are rugged trucks. It will have the big V-6 engine. It is a high torque engine at low RPM witch is good for a truck like that. Parts are harder to get for it then the Chevy V'8s. I would rather it had the 366 or 427 chev. engine. It probably has a 5 speed trans & either a twin screw rear ends or tag axle. It will make a good toy bbut if you are going to run up & down the road with it you need a diesel.
1972 Chevy c10 Cheyenne Super
They are good trucks. I drove a '71 9500 that was the same color. I used to own a '67 7500. The V-6 gas is a good engine, but as stated above they are hard to find parts for. That would not stop me from owning one tho. They are also know for not so great gas mileage, but if you super-tune it, it should do OK. It most likely will be a 401 or 478 V-6.
Let us know what else you would like to know about it. I'd be curious to know what trans it has.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
3B Offline
Hy barndoor, could you please be a little more specific with your question, thanks
3B #505019 02/12/2009 3:15 AM
thanks everyone ! I found it for sale this morning,I have been looking for a "big bolt" for months,for a toy.There is not much info on these out there,so any and all info is appreciated,I might go look at it tomorrow.I am pretty sure it is a 7500,I think JM7500 or JV7500.On another note,I was told today you need a CDL to drive a truck with air brakes?
'57 GMC F350
'49 VW
barndoor #505047 02/12/2009 3:48 AM
A CDL is reuired to drive any vehicle with a gross combination weight of 26,001 lbs. no mater what kind of brakes it has. If you are planning on driving it on the street, you will need a CDL and check with your insurance agent. I am in the trucking business and have several old heavy trucks. I can insure them through JC Taylor because I can prove that they are collectors items, not feasabable to use in my fleet. If you only have one big truck, most insurance companies will assume that you will use it as a truck.
crenwelge #505065 02/12/2009 4:11 AM
thanks for that info crenwelge,and
C10 - C90 Bill,I was told it has a 5 speed with a browning 4 speed and an air locker rear end.
'57 GMC F350
'49 VW
crenwelge #505068 02/12/2009 4:18 AM
The truck is heavy enough to require a CDL (normally). I'm going to say that the GVW on the truck is at least 41,000.
It looks like it is a 7500 Series.
Keep us posted.
GMC 9500 Fan
Detroit Diesel Fan
Interesting trans. It will be a challange to drive, but yet a lot of fun. I'm sure the owner will give you some pointers if you are not very familiar with it. You really won't need all the gears just to get it home, but you will need to use them when carrying some weight.
Sounds like a "Pulling Tandem" (All 8 rear wheels will drive when needed off road).
GMC 9500 Fan
Detroit Diesel Fan
I've got a '72 GMC 7500 6X6 ex-air force wrecker. The V6 is a bit slow up hills but it's fun to drive. here are some pictures
http://rides.webshots.com/album/563616467iqvoxl
That is one heavy duty unit, I like it, looks to have the same gauges as my cabover in the dash. What is in for a transmission?
Steve
topkick #506038 02/15/2009 2:09 AM
it has a roadranger 10 speed overdrive.
barndoor #509181 02/23/2009 1:42 AM
I haven't even had a chance to go look at that truck (its 50 miles from me) If anyone has an interest in buying it,I will be happy to help,I just bought a '59 GMC LCF,so....The price on that truck is very reasonable,contact me and I'll put you in touch with the owner.
'57 GMC F350
'49 VW
barndoor #509241 02/23/2009 3:16 AM
Wish it were closer (it's on the wrong coast,lol).
GMC 9500 Fan
Detroit Diesel Fan
barndoor #510783 02/26/2009 5:41 PM
Where is it at can you get back to me about who to talk to?
Repair #513677 03/05/2009 11:41 PM
I got ahold of them guys, Got some pix, Theres some rust on it (Holes) No pix of the motor compartment.
They are just sitin on it. They dont send the pix i want & wont say what the motor is or if it runs or what.
They said they would get back to me & to just hold on.
Also said it is not road worthey.
It had been a yard truck. Said it would have to be halled.
Tires are no good & some of the beads are loose from the rims.
They sure are slow to get the info back to me.
Bill what size & HP would the motors in there be, Its a V6 gas i think.
Repair #513756 03/06/2009 3:37 AM
Repair, As mentioned earlier, I would say that it most likely would be a 401 or a 478 V-6. It looks like the 401 has 178 HP and the 478 has 206 HP, but these engine have big time torque! If either one is a Magnum engine, they will have about 20 HP more.
Did you try to get a phone number?
GMC 9500 Fan
Detroit Diesel Fan
Bill yes got a ph no, they dont answer, Leave a message thing.
Just called them been 3 days, Havent had no E's or phone calls.
Asked again fo E pix & motor size.
Want to put a 20 to 22 ft. box & hoist on it, I would think maybe the HP would be to little, What do you think?
It would hall 6 to 700+ bu.
Around 40000# of corn + Box & hoist.
206 Hp I would think would be to small, I fixed up a truck that
had 350 Hp it worked good.
Repair #514140 03/07/2009 3:18 AM
Would you be hauling 40,000 number of corn? or 40,000 lbs?
GMC 9500 Fan
Detroit Diesel Fan
It would be 40,000 Lbs, Corn is 56 lbs to a bushel dry.
When it comes out of the field it's usually got to much moister in it so it weighs more.
But 40,000 would be close.
Repair #514746 03/08/2009 5:27 PM
Well, 40,000 lbs of weight would be too much for that truck. It could have Fronts as low as 7 and the Rears are most likely 34's. That would be 41,000 GVW. The truck with the box and hoist will be somewhere around 16,000. That would only give you a carrying capacity of 25,000. The 478 V-6 in that truck would have no problem pulling 25,000, but it would be a little slow getting up to speed. I used to pull 20,000 with 478 in a single axel truck and it had plenty of power. For cubic inches and HP the 478 is very strong. As mentioned earlier it has tons of torque.
GMC 9500 Fan
Detroit Diesel Fan
C-90 Bill
I dont know what the axels are. They dont answer any of my phone calls or E Mails, I think They dont want to sell it to me cause im to far away from them or the think it's a joke.
Never had this happen befor, I have bought trucks from several states & never had a problem.
I eather drive them back or haul them.
Thanks for the info.
